4" lift for 35" tires??
cok5
4\" lift for 35\" tires??
I just got a helluva deal on a 4" lift kit. Will it clear my 35's OK, without cutting? Don't do a lotta crazy ass wheeling, cause there are no rocks out here!
Re: 4\" lift for 35\" tires??
Yep, I believe you will definitely have to trim a little. More if you wheel it hard.
if you leave the sway bar on, and dont do a whole lot of articulating, you could probably get away without trimming. its something you will have to wait and see how everything lines up when you install the lift.
I ripped the chrome strip off of mine and smashed the back of the front fender with the same set up. I still had the sway bar hooked up too. You can trim a little and run street and some mud without probs.
I second big83chevy4x4, I ran 35's for a long time with 4". I Actually let the tires bend the front wheel wells out of the way for me.
You can get 35's with no lift if you don't move the suspension at all. With 4" you will need to trim but like Bubba said, search a bit, you might even find pictures /forums/images/graemlins/thumb.gif
This search function on this board is a little weird to me. Brings up the topic plus all replies seperately, makes one day take up 10 pages. Most boards just have the topic, and you have to click on that to read the replies. Just a little weird for me.
This is what I found helpful, instead of just using " " around the subject, below the box, click "in subject" instead of "subject and body" so now the title will just appear. /forums/images/graemlins/thumb.gif
Another idea would be to add some Zero Rates both front and back. Or you could also think a small body lift with poly mounts.
Without the sway bar, I used to rub 33's (32" actual height)on a 4" lift kit. With 5" of lift, my 35's can hit the inner fenders when I'm wheeling. With the swaybar, no problems. I have just been trimming whatever gets mashed by the tires.
This is just my opinion: 4" and 35's looks really good, so the trimming is worth it. 33's look a little small under a 4" lift and 6" is too high just to clear 35's.
The rubbing also depends on the brand of spring (some put the center hole in different places) and the backspacing of your wheels. Also, old body mounts will bring the rubbin on much sooner.
I've got 35" SSR's on mine with a 4", zero rate in the rear and the little extra from my 14bolt /forums/images/graemlins/cool.gif Had to trim to fit with no rub, and checked it out on the trails with no probs at all...go for it dude, you wont regret it!/forums/images/graemlins/hack.gif
[ QUOTE ]
[/ QUOTE ]
Your Blazer looks really good man
ive seen tons of people run 4" and 35s. Not sure what you all are smoking. Is my truck strangely high. Idon't think it is. I run a 4 inch rough country and 35 procomp mts. I have had no problems with hitting fenders, EVER. Ive even seen some do 2" with some body work.
chev4life how much did you cut and do you have any pics. i love the way ur truck looks, i was wondering what size lift and tires to use and you've just made up my mind. anyway im just not sure how much to cut, cause ur's pretty much looks factory. nice lookin truck man
You can see how much I cut in these photos...
http://www.sounddomain.com/memberpage/207692/11
I dont really remember how much dimension wise I cut...roughly 2" from the front and maybe 3-4 from the back...pretty much as far as I could go without getting into the inner fender structure (second layer). I still need to tack up the inner and outer fenders and a little clean up. Thanks for the compliments.
[ QUOTE ]
[/ QUOTE ] I can understand where you're coming from with Rough Country. But I can also see where others are comming from with TC and BDS. /forums/images/graemlins/thinking.gif /forums/images/graemlins/whistling.gif
[ QUOTE ]
[/ QUOTE ]
I have the exact same setup and my fenders hit when I climbed a big rock and but a cut into the tire lug so I just cut back to the fender well and know I have no problems.
Well I guess this search function is not working properly on mine!! I tried the quotations, and the the "in subject" button, but still brings up all the RE: stuff. Typed in "4"lift" and it had 35 exerpts just from today!! I dunno!
