4" lift front springs - anyone remove one leaf?
Jersey
NJ
4\" lift front springs - anyone remove one leaf?
The rancho 86206 "soft ride" springs in the front of my k5 are loosening the fillings in my teeth! soft ride with 520lb/in rated springs...i don't think so. i have checked and double checked everything else - greased bushings, loosened shackles, removed sway bar, removed shocks...tried everything and still rides stiff as h*ll. I've read a lot of you guys praising the ez rides by TC but before i go spend another $2-300, i was just wondering if i could soften the ride up by removing one of the leafs? It uses 5 and i figure i'd remove #3 from the top. I'm sure i'll probably loose about an inch or so clearence but i can deal with that. Has anyone ever done this or any suggestions? Thanks in advance.
- Jersey
Re: 4\" lift front springs - anyone remove one leaf?
i removed my overload spring for the front of mine, it gave it a much softer ride and better flex, along with about as loss of about an inch of lift. the most it will cost you to try it is a few center pins and bit of your time
good luck
marc
remove the overload and install ORD's zero rate add-a-leaf. That way you keep the same height and lose some of your spring rate. Enjoy
I removed 2 of the 5 in my skyjacker fronts and one of the rears. Made a big improvement. Lost some lift but, my 4 inch was about 5 inches new.
my brother removed 2 leafs from his pack on the 73. i just put some ranchos in the 72 and wish i would of left the TCs. i'll probably do the same and remove 2 leafs. i'll loose some front lift but i wont have to waste time and $$$ lifting the rear.
ARQ.
thanks all. So it looks like i'm going to try it, just need to figure out which one to remove to give most flex without loosing a lot of lift. I thought the bottom two springs would be the ones holding the lift up the most and the top three actually combined for the rate per inch. so, i figure i couldn't remove the top one (duh) so i figure to loose the #2 or #3 from the top.
Is it possible to flip the overload so you won't lose the lift? I know you can do it to the rear maybe you can do it to the front also. Just a thought.
i'm not sure if the bottom spring in the front is used as an overload and i'm thinking that the only thing that would do is decrease the lift amount, which i think the main purpose of the bottom 2 springs are for - lift. I think the top 3 or 2 mostly make up the rate of the spring. Then again, i could be completely wrong! maybe someone with more experience and knowledge on this will shed some light. Thanks to all again for all the input.
- Jersey
