crashandburn
I've got this 94 S10 Blazer with a 3 link SAS up front and triangulated 4 link in the rear. It works fantastic, except one thing. The torque roll is pretty bad. It can be pretty scary climbing a rock on the driver side, while the passenger side is my strong side. I recently read that antisquat can cause this. Previously I hadn't given it much thought because it does not squat or lift under load. It stays put really nice. So I thought my antisquat was good. I have no sway bars and a lot of suspension travel.
My question is: Antisquat is calculated as the relationship of the angles of the upper and lower control arms, as they relate to the center of gravity. I can map out the control arms and where they would theoretically meet, but how do you figure out where the COG line is?
Being a full bodied rig, I could only get my upper control arm mounts on the frame as high as I could get them. I do have pretty good separation at the axle. Based on the problem I'm having, should I try lowering the attachment point of the upper control arms at the axle?
