4 link or radius arms
Babaganoosh
1 ton status
Phoenix Arizona
It looks like the time has come to link the front end of my truck. I have done research and have a decent understanding on paper. I haven't played with numbers yet in a calculator.
What is the difference between a triangulated or parallel 4 link? I'm leaning towards a parallel 4 link because of clearance issues.
What do the experts think? Once I get behind a keyboard I can elaborate note.
Just finish the project you already started is my vote.
Martin
I was thinking of a mini truss. Sorry I forgot to add this is for the front.
I want more then the leafs can give and a different quality of outcome.
I never should have driven the Jimmy to your house. I created a monster who will never finish his truck.
3 link the front. I did radius arms first. Was OK. Went parallel 4 link. Had to go full Hydro to remove the bump steer.
Now 3 linked. Very happy with it.
Wade, yes you should have. I did fall in love with your setup.
What did you try these all on? I figured radius arms would be OK with what I want to do. I don't want to do serious crawling just want the travel and simplicity?
How did you get bump steer? I properly built pan hard would take care of that no?
You could just save up your pennies and order ords:whistle:
Had to go dual cross over. It was bump and push steer as the arms were not parallel or long enough. Just felt weird. Front end moved side to side 6 inches. Try landing that at 50 MPH. It worked, just not well.:doah:
This is how it sits today. 6 years of wheeling. :woot:
Picture whoring ahead.
Could you get some better pics of the panhard and the tie in points of it?
That makes two of us Adam.
I'm curious if I would need to build a drop member to hold the links. I'm pretty sure Wade had to on the jimmy.
I attached all 3 front links to it. Looks like I found it on a John Deere tractor. I have beat the crap out of it. Never really has limited where I go. But it does hang down a ways.
Was this because of the placement of the links or did you do it for structural reasons?
Because I over build everything. And it was not being built for rock crawling. So clearance was not a priority. It is bolt in though. Would have to remove it to pull the trans.
Overbuilt isn't a bad thing.
Was bump steer the only reason you got rid of the radius arms? curious if it's something thst xould ve fixed now?
how about a radius arm set up
ive been thing about doing that to the front of my 87 K5 just not sure about how to do a pan hard bar
How limited is the flex? I don't need a ton, but want travel. I know they go hand and hand together. I was think 14 inch travel should be in plenty, how much do you have in the jimmy?
