4"rear+4"shackle Flip Any Problems...
KohlTrain
Registered Member
Ione, Ca
Been searching but havent found right answer. Any problems with this:6" tuff country and zero rate front and 4" rear skyjacker spring with 4" shackle flip. My main concern is the 4" springs and a shackle flip.? Will this work ok?
Yes it will work, but your shackle angle will be less desirable than if you were using stock springs due to the increased arch in the springs. When i was building my suspension in '05 I found that a shackle flip + 4" lift springs was not much height difference than a 12" lift spring with stock shackles.
Thanks for the input. Decided to go with the 4" rear springs,2 1/2 shackle flip,and 6"shackle. Should net me 7 1/2" in the rear and 7" in front. Swapping out to 14bff at the same time. On paper this should work out sweet! Time to get busy
