4" TUff country lift problem
Pow06er
ne, ohio
ok so i get my 4" lift kit with rear blocks for my '88
and i look at the blocks and notice they are big like about 5" big so i look at the instructions to see the listing of parts and it says
2-5.5" lift blocks
so i figure they must be right
so i install them
and now i relize after chatting with other people who have k5s and run TC lifts that they are too big and i need a 4" block and that the front should be noticeably higher due to new leafs and they will sag over time to level out
so now i gotta remove my 5.5" lift blocks and ubolts and try to see if suspensionconnection can overnight some 4" lift blocks and new ubolts
and then hopefully have them send me a addressed box so i can mail back the 5.5" blocs
im pissed to say the least
altho i did drive it and i had some vibes but were changing the ujoints and hopefully the 4" blocks will give me a tad better angles
not a bad thing
Most blazers are higher in the front than the rear. the extra height is to level it out. My skyjacker softride came the same way when I had a 4" I had 4" springs on front and a 5.5" block on the rear. leveled it out nicely.
yea but mine wasnt sagging at all stock i think there is an aal back there but dont know for sure the PO said there was one but i dont know
damnit im lost at wat i should do
whats the problem? do you not want that much lift? i think you should just stick with the 5.5" block for now. if its just a matter of you wanting it to be level, then get a zero-rate in the front, then youll have another inch of lift to even out with the rear aal, and you could move the axle forward if you want.
thats what i would do.
i do see ur point tho, contact them and see how they will compensate you for the inconvience.
Leave it alone!
You will want the extra lift in the rear. I have a tuff country six inch all spring lift on my 90' blazer, and had to add a set of two inch blocks out back to level it up. The rear is about 1/2 inch taller than the front with the top off,but it is dead level with the top on. Good choice of springs. You will love them. I have a total of eight inches in the back and have zero vibes.
well i already have a 0rate in the front with my new springs and the rear still sits higher up about 1/2" it doesnt bother me aobut where it sits now but
one is the front springs are gonna relax a bit and then its gonna look even more lower
another is the truck never sagged in the rear at stock height
and lastly i dont want to be this high in the rear im already getting a vib at 0-30
and when i let off of the gas about about 30 mph i hear a grinding noise we think its the ujoints so we are replacing them
so im calling TC and telling them i got the wrong blocks
Personally , I prefer the rear too sit a little higher then the front. I'd just run it as it is till a later date and then go with a shackle flip, or rear springs. (Note; I'm no fan of blocks)
when I installed my 5.5 block it through my driveline angles out of wack and had a bad vibe so I used a 4* shim to tilt the pinion down
it got rid of most of the vibe had one around 5 mph
but my angle were maxed out
my only other option was a cv driveline but it would of required a huge freaking shim so I decided screw this and I ditched them for a 4inch shackle flip
On most Blazers the rear 5.5" block will make it sit level with 4" front springs as already mentioned. You stated that your Blazer in stock form already sat level, and that you thought there was an AAL installed in the back.......there was no way for the suspension company to know this unless you told them before ordering the kit.
In any case, call them up and they would probably be willing to exchange the rear blocks.
yes its been done im getting a 4" block from suspensionconnection overnighted and im getting a call tag for my 5.5" blocks very good customer service
Im contemplating making up some 1" flat bar to use as a drop tcase to give me better angles
if i do the 4" block thats tapered and then go and do a 1" tcase drop will the taper in the blocks and with the lowered tcase overcorrect and give me too much of an upward angle on the pinion?
