4 wheel drive no worky..............
BurbinOR
3/4 ton status
Oregon
On my '89, you can pull it back into 4 wheel but the front will not engage..........dang I hate these non mechanical front hub setups. Any idea what this could be?
I'm positive it doesn't work............bud had it with us up in the snow the other day and had to pull him out of a drift - back tire was turning (no posi/locker /forums/images/graemlins/frown.gif) and no movement from the front.
Good thing it had studs on all 4 corners. We were in some serious nasty snowstorm up on Mt. Hood.
/forums/images/graemlins/thinking.gifMost likly the vacuum swich on top of the transfer case is not working or is not geting vacuum. The easiest way to check this is to hook vacuum up directly to the actuator that is under the battery. if it still doesnt work the acuator is no good ,if it does work the switch on the transfer case is no good or is not getting a good vacuun signal /forums/images/graemlins/thumb.gif.
[ QUOTE ]
[/ QUOTE ]
Thanks, yes it is an 89 (thanks Tazz), auto trans, factory everything including no external hubs. I'll check out as per your troubleshooting ideas, appreciate the help.
Most likely the vacuum switch. The one on our '91 S-Jimmy started sticking around 100K miles or so. New switch cost about $18 at the GM dealer. I had to drop the linkage to the transmission in order to get my hand and a wrench up to the switch. You can't see it from below, just feel around on top of the t-case for the 3 vacuum lines coming from the switch. /forums/images/graemlins/shocked.gif
[ QUOTE ]
[/ QUOTE ]
Thanks Harry.......... /forums/images/graemlins/thumb.gif
