jgolden
Registered Member
I'm putting together parts for my build and I have a few questions about your "long travel" suspension setup for the front and rear.
Vehicle: 1984 3/4 ton Suburban with 1 ton axles
I would like to run your Coilover conversion in the front with a bypass shock and a bump shock with about 4" lift and 64" rear leafs with big shocks through the bed and 40" Goodyear MTR's. The goal is a low stance, maximum suspension travel and full articulation with a large tire. - I know the fenders need to be trimmed front and back, I'll probably run fiberglass in the front. The rear will be heavily trimmed and I'll Tub the wheel wells if necessary. The vehicle will be used as a Family Expo Rig around Southern California and some Prerunning / Exploring down in Baja, Mx.
Here's my question: What other modifications do I need to address to obtain my setup. Will the 40" tire hit the Air Conditioner, Batteries or anything else in the engine bay at full up travel or full articulation? I would like to get 14" or more of front and rear travel. I'll be running a Dana 60 up front and 14 Bolt rear - Is 4.5" backspacing the correct setup for wheels?
Thanks in advance for your help.
I'm looking forward to starting the project
James
James
