400/203/205 doubler
fourwheelerjeff
I spend too much time here
Staff member
Moderator
SW OK
Th400/NP203/NP205 doubler; 32 spline
1410 Yokes and driveshafts with .250 wall 3" tube with Spicer ujoints
400 was recently rebuilt and has 3 runs on it, this is a first gen ORD doubler and the 203 is clocked upside down; it can be rotated around 180 degrees. the only shifter with it is the 205 shifter.
asking 1750 with the driveshafts
for another 500 i will throw in a 350TBI
Pics please......where in Texas ?
meadow; by lubbock. i can get it closer to you; san antonio is no problem
i didn't build it or buy it; but from what i was told; it is a first design doubler that you clocked where you wanted it and then welded it together. it is probably at least 10 years old. also, you can turn it 180 degrees and then the 203 is not upside down.
What would be the benefit of running it upside down? Would you have to do major floor modifications?
