400 SBC block,crank,rods,heads UPDATE
J
J.R.
Guest
virgin block 2bolt mains. block, crank, rods, heads,damper and flexplate all go.. was a running motor when pulled, i tore it down for inspection.. asking $375 thanks
for thanksgiving im going to be in the KC Kansas area and would be more then happy to bring this stuff along and meet somewhere!!
mike reeh said:
thats a good deal. if you were closer Id snatch it up just to have an extra.
I have one ready to go, here in sac CA
check my for sale post
the head numbers are 488642.. wasnt able to check block numbers.. i can get the block numbers and will measure the cylinder bore,main bearing bore, rod and mains on the crank over the weekend. i know the block isnt a 509 block..
thanks, oh and i can deliver these parts to des moine iowa, omaha, ne., and st.paul, mn areas...
If you look on the side of the block, I think the passenger side, you will have the last three digits of the block casting, in my case 509:D
But you can also get the complete number on the back under the belhousing.
