I'm rebuilding a 400 and was running the casting numbers. I got the block figured out (330817, 72-80, 2bolt, still looking for casting date), but when I did the heads ran into some confusion. The numbers are 458642...which show up on MorTec's website. But it's showing they only came on 350's. Now I know I have a 400 block (casting # proved that, and it has the "dimples" on the sides). The site is showing 333882, 468642, 3951598, 3973493, 3998997 comming on 400's. I am 100% possitive that my #'s are 458642...even had to other people read them.
The guy I bought the motor from said it had been rebuilt once and he was the original owner. I don't really think he would have swapped heads, especially from a 350...he knew his way around a motor.
My question is, would I be ok running these heads (assuming they check out ok)? If they were off a 350...I'm betting they've had the steam holes drilled already (haven't pulled them yet). The motor ran and made good power, but smoked allot (looked like you were pouring oil down the carb). It didn't smoke at start up or when idleing...just under load. So I'm thinking it's the rings, but I'm not gonna throw it together without going through the heads.
I was also looking for the chamber size and valve sizes, but couldn't find anything.
FWIW: This motor will be going into an 88 Camaro (I'm up to 4 now
) with a 700R4. I'd almost like the heads to come back cracked so I can get a set of aftermarkets...but the budget is a little tight for that.
I put the socket on there and gave it a twist with my hand and it broke loose! On the plus side it is an actuall rod bolt that he replaced it with, just a longer one. Surprisingly the motor did not knock any (had low oil presure though). I had it running in my K5 a little over a year ago and in the Camaro friday night.
