87 Blue Beast
i have a few questions about the 400 small block since im thinking about building one. first off, i know everyone says that the 2 bolt mains are actually stronger than the 4 bolt blocks. this is true right? then i also heard that the 2 bolt blocks are only better if you machine them out to except the 4 bolt caps? i dont want to have to deal with the machine work to make the 4 bolt caps fit the 2 bolt block. so all in all, is the 2 bolt block with 2 bolt caps still stronger than the 4 bolt block? ive heard that the stock block will take 400hp easy. if thats right, then ill be fine. thanks guys
