ive never put the desktop dyno up against a real dyno...but i belive its accurate...i use it to build motors..ive built 3...i have sat and looked at a jegs and looked at cams and said man that is a bad a$$ cam for my motor...then when i pluged it in it wasnt so good...i have gained nearly 50 hp at one time just from going from 1 cam to another in the program..its very use full and i dont even know how to use the hole thing...
if you are hardcore into getting the best bang for the buck get the cam calc to a get a custom ground cam (lots of $$ though)...
if i had to do it all over again i would run a roller cam..you make more power,its alot better piece of metal,and it will last a whole lot longer...sure they are expensive but just ask 4x4 high they are worth it..
