I thought I fixed the problem with my engine running rough last week but when I pushed and tightened up all my plug wires it seemed to help initially. Now it seems to be a bit worse. It is idleing rough and when I give it some gas it acts like it is not running on all cylinders or missing and sputters a bit throughtout all gears and RPM ranges. No backfires to speak of. All the plug wires seem to be on tight. It doesn't die or stall too bad. Could it be the timing (HEI), which I know nothing about or how to adjust? New fuel filter installed about a month ago before last wheeling trip. It seems like it has to be something in the electrical system which makes me think it's the HEI. What should I check as I'm kind of at a loss? Being that I'm not the best mechanic in the world should I just take it to a local shop or could someone give me the quick version on adjusting/checking the timing etc. Thanks in advance fellas.
Hoby
Hoby
This is where I'll start but I can't really do anything til after Thanksgiving. Leaving in 3 days to go dear hunting for a week. Please keep the feedback coming as this may not fix the problems. Thanks again for the replies thus far.
