44 inch boggers
check out this site http://www.home.no/royhansen/hummerbilder.html
:doah:my bad.. I don't know anyone that has done that and can't find any pics, because the h1' are to narrow you would have to get them widend and recentered I'm sure it has been done some where but prolly just to say it can be done
I have seen a ton of people running 44" Boggers or TSLs on stock width H1's.
there is absolutely nothing wrong with running 44/47/49" interco tire on a stock width H1 rim
it can be done. but the thing people, and that I, worry about is having ~9" wide H1 on a 18" wide tire. when i first mounted my H1s, they looked sick, but decided to widen my H1s. actually found a really good deal on some widened H1s so i jumped on 'em. of course I had to get some pvc inserts from USA6x6...it just makes sense, you widened the wheel, you need to widen the run flat/ insert.
i would like to keep my truck as narrow as possible....i really didnt even want 44s but i couldnt pass the deal up...i hope i can fit them with 8 inches of lift..
I'm running 42s with ~4.5"s of lift. You should have no problem
even with trimming i think i will prolly still eat the fenders...
What he said...:hack:
Or you could link it and run coil overs. :thinking:
The bigger issue is the front end and how much the axle moves front/back during flexing.
