supersize75k5
OrganDonorRacing.com
Need to impress your cousin or lift your ugly truck so high it's like a beacon of hope for rednecks everywhere, thus drawing them into to your neighborhood till the values on the homes crash and you can scoop up the rental you're in for cheap?
These tires make a home owner out of everyone that buys a set.... eventually!
(3) 44"x18.5x15
(3) 8 on 6.5 steel rims with welded bead locks
Tread? .............. Lots. Nice and deep, it's like driving on tons of little Grand Canyons.
Condition? ........ Round with some rock rash
4th tire was damaged but can be included for the low price of free! No 4th rim.
Would you like to be self insured knowing you are safe from flood waters but lack the trust that FEMA will come though?
These are the rubber for you! Enough rubber here that you better have a Ron Jeremy sized drivetrain to handle it. These are called the super swamper TSL.. They literally just call them super in the name, talk about oozing confidence!
These tires and an accompanying lift kit will turn that boring currently reliable daily driver into a non certified usually stationary flood shelter! I'd recommend you paint the truck camo if you wish to not be the neighborhood hero to very 8 year old in vicinity.
All that said, this isn't a slam dunk on the American dream. I've enclosed a map of the confederate states where these tires are still worshiped. Using these outside of this area is completely on your own accord and I assume no risk if there is damage to your family tree.
Pick up a 4th tire or use these to build a set or get more life out of a set you already have!
Located in Mesa az 4802283218
600.00 or will split up for 250 each.
(3) 44"x18.5x15
