broncoman6524
On my parts truck (3/4ton) and the blazer frame (1/2 ton) i swapped the 44s today...got the new lined up in hte blazer.
tried to put on my older/longer u-bolts too narrow!
what the H*ll? the ones from the 3/4 fit perfect...but i have to move the perches from truck to truck and seeing as yuo need u-bolts holind them down to get the swaybar off...im kinda screwed at the moment (alone)
Anybody else have this problem? NO its not a 60. gears look the same, says 44in the corner under the diff cover.
what the H*ll? the ones from the 3/4 fit perfect...but i have to move the perches from truck to truck and seeing as yuo need u-bolts holind them down to get the swaybar off...im kinda screwed at the moment (alone)Anybody else have this problem? NO its not a 60. gears look the same, says 44in the corner under the diff cover.
