CO 454 7qt oil pan & oil pump
mrk5
The Sticker Guy
Moderator
Vendor
Author
Northern Colorado
I ran this 7qt Milodon pan for about 1 year on my 454. Ultimately I decided to take it off because I wanted a standard volume oil pump and a little bit smaller pan. Also with my high-steer setup the oil drain plug was pointed right at the ram and I couldn't drain it without making a mess all over the steering and axle.
The part number for the pan is 31100.
The pump is a Melling High Volume pump with the pickup designed for this pan. You can see in the pictures I dinged up the pickup tube when I was installing it but it didn't affect its function.
New the pan was $249, pump $58, and pickup $54. I'm also including the Milodon dipstick which was $62.
I would like $150 +shipping for everything. I could also likely arrange to meet within 50 miles of Evans, CO.
