def use oil with higher zinc content, also regularly start the truck and warm it up even better to drive it aroudn the block. what happens is when it sits the oil drips off the cam and lifters and they are dry on startup.
Sound like that's the original posters problem.. the engines sits, the oil runs down into the pan, and then on startup it's trying to push a 50 weight oil back up to the top. It wouldn't surprise me if the pistons were slapping a bit too..
I'd def. go with a thinner oil..at least if you switched, and it still ticked, then you might be onto an actual mechanical issue, not related to lubrication.
Guys like to choose a thicker oil because it's assumed they protect better - problem is, thick oils don't flow good when they're cold. You can have as much zinc in there as possible, but if the oil isn't getting there, it's hello wear and scuffing.
What you want is an oil with film strength - If you haven't seen it, check out my vendor thread link below.. check out our Quantum Blue oils.. we can blend them with as much zinc ( or as little ) as you need, but here are a few things about us that are more important:
1) Combustion temps won't cook out the additives, or fracture the basestocks, which is why lubes break down...even synthetics aren't immune.
2) Our oils contain no PTFE, MOLY, boron,or any crap that leaves deposits. No solvents either..
3) Our lubes are tacky - which means they cling to surfaces when the engine just sits.. we're talking wet cylinder starts, regardless of conditions - and the higher film strength means you don't need to run a 50 weight.. we can whip up a 30 or 40 weight full zinc oil for you that'll outperform any name brand oil you can think of.
4) Our anti wear capabilities exceed those of mobile one.. there's an article in my vendor thread describing how we beat mobil one in some dyno testing in the GM Z06 crate motor.
Now, some are gonna call BS.. that's fine.. but look at my thread at least.. if you see something of value, PM me.
