454 BBC TBI on SBC
4X4HIGH
1 ton status
Fremont, CA.
What are people doing about the TV cable hook-up and the cruise control cable on the TBI? I have a BBC TBI but there is only one provision for hooking up the throttle cable, nothing for anything else. Also I thought I seen somewhere there is an electrical wire adapter for the TPS switch but what about the IAC?
Ok, I just found the adapter wiring and its for the IAC not the TPS, (turbo city #975-325 = $19.95) I also discovered that GM used 3 different styles of TPS switches of which 2 are interchangable.
I am thinking about taking the bracket piece off of the throttle shaft and replacing it with one I have off a spare SBC TBI. The other thought is to just swap out the whole shaft depending on how the throttle blades attach to the shaft. As long as the throttle blades don't go through the shaft then I can just enlarge the openning and go that way.
