I have a fairly large coolant leak somewhere on the back of my 1989 454. When I got home yesterday I noticed the puddle so i started it back up. Its draining down the driver side of the bellhousing/inspection cover. I stuck my head in the fender and looked up under the inner fender, and I could see it running down the area with the casting numbers, but does not appear to be coming from that head.
What could it be? I know the freeze plugs are lower than that right?
Intake gasket?
Coolant lines? Not sure if there are any that go into the back of the intake?
The truck never got over 190* on the drive home so it just happened out of nowhere
Intake gasket?
Motor was up to temp, and the area near the casting numbers was dry. I took it for a drive around the block and when i came back it was dripping about the same again
It was leaking on the driver side where the block/head/intake meet. Replaced the coolant temp sensor and fixed a couple bad vacuum lines as well, but still have the running bad after it gets to operating temp problem in this thread.
