how come 781 and 049 heads are $$ my dad wants to build a 454 but the motor he has, has crap heads, any alternatives ?
http://www.carcraft.com/techarticles/ccrp_1010_cheap_big_block_chevy_engine_build/viewall.html
Up to 500hp on peanut ports.
that's what I was thinking, a cheap cleanup/valve job with some mild porting, and you'd be into those heads the same as buying a new set that still need to be rebuilt.Yeah, depending on what he wants to build and how it will be used, his "crap heads" might work better.
I do know a few guys that have used the peanut port heads from the 80's-90's and they fall flat about 3500, when you might really need them for pulling a hill while towing.
Dang wish shipping wouldn't kill it. Seems like I can find 781s every now and again for dang near free
BTW I did a couple different versions of a desktop dyno type setups and talked to a guy who has built several and done 781 swaps on trucks that had peanut port heads on em.
The max torque did not move nearly as much as you think it would. Like less than a thousand rpm.
The good heads made a better average torque over then entire powerband.
While you can build peanut port heads, when combinded with the correct cam the 781s ( I don't know much about the 049s plus my buddy has used almost all 781s just easier to find I guess) produced more torque from about 2200 rpm and up.
I have watched my tach a ton while crawling I am usually above 2k
If you want to look out I will but shipping would probably kill it
