454 oil pressure?
johnathan
Ocean Springs,MS
The oil pressure on my big block reads 50 psi+.This is a bone stock 454.There is a slight rise as I rev it. Now,the other morning I crank her up and its reading much lower 15-45 psi. with much larger fluctuation as I gas it.I pull it around the yard shut it down and then when I crank it back up ,back to 50 psi. Would this indicate bad oil flow?This is a good quality manual guage. Now I have a squeeking noise coming from the back side of the motor weeenk weeeenk?
How old is the oil filter? Mabe it is clogged and the oil bypass valve is opening. Is it a fram? Fram filters are notorious for causing the oil bypass valve to open and drops in oil pressure.
