Thumper
I have a stock 454. Its out and the crank is going to the shop to get turned this week. Is it worth it to me to install a RV cam (or something a little torqier than stock) right now or not bother. I will be running a stock Q-jet and intake, as well as exhaust manifolds. The cylinders are stock, and arent being touched. Would a cam make any worthwhile difference?
Thanks
Mike
Thanks
Mike
Need to find and fix problem then it should get better milage.
NOW is the time to do a cam swap, while the engine is already apart. It's not a fun job to do later. You can bolt on headers any weekend.
