COCHEV
ok, so picked up a rebuilt 454 short block- 1985, casting # 14015445- rebuilt to stock . my burb has the more desirable 049 heads and i would like to use them on the 85 mill...will this all be ok? what should my compression be? I also have the heads from the 85 mill which are the 045- oval/ open. from what i've gathered the 049s are the way to go, just want to be sure they will work with the newer block.
also open to cam suggestions. want monsterous torgue, good idle/vac. will be eventually goin in front of a sm465...
thanks,
jason
thanks,
jason
