I have a 94 gen V 454 and will be putting in a big cam part # 249-k11-318-4 from jegs. Will it work with stock valvetrain that has the non-adjustable rocker arms? Or what will I need to do to make it work using the stock heads
You will need to go with an adjustable valve train to work with that cam. In fact the conversion studs will be marginal with the springs that cam will require. Ideally the heads should be machined to use conventional studs and good quality roller rockers.
