I know this probably belongs more in the ebay/CL postings section, but I have a few basic questions to ask about what looks like a good deal I just can't pass up.
I've been keeping my eye out for a 454 big block to put in my 86 k10 that I am swapping 1 tons and 38" tires on, and I think I might have just found the truck to take it from.
It is a 1995 C3500 dump truck and the dump is currently KO because the frame mounting is ripped out / damaged. PO says it tore a hydraulic line or something during its last use too. Miles are unknown but it was used as a feed truck for farming locally so it was never run very much over its life, the miles are suspected to be about 65k.
Aside from the needed fabrication repairs to the frame and the obvious rust on the dump box it appears to be in pretty good shape overall. The best part is I can pick it up for $1000.
My question is if that motor with what appears to be a serpentine setup is a desireable transplant? I know this isn't a simple drop in operation and there are difficult considerations such as fuel tank / pump setup, wire harness & ECM installation etc. However, going with a toilet bowl EFI BB over my current SB carbed setup sounds like a good option.
From what I read, the horsepower specs seem awfully low though at like 230 horsepower and 385 ft.-lbs. of torque. Is this motor a good candidate for basic mods and such? The VIN code is "N" so I know it is a TBI 454.
If I could fix the dump box, this thing would be awesome to have around my property for yardwork etc. I would put one of my 350's in it instead and call it a day instead and use the BB in my rig. I'd even consider putting it right back up and selling with the motor and harness removed.
What do you guys think?
