What to reasonably expect from a TBI big block. 2wd suburban.
I'm thinking 10 on the freeway
OD or no? Probably get 11-12 with OD
No overdrive just means I'll likely set the cruise at 65
Isn't that the whole problem you're trying to get away from?![]()
Being limited by power is not the same as being limited by fuel consumption
Boost the 6.2 overboard into the lake!Boost all the things!![]()
