So I had a few hickups and some backfiring that started to get worse then finally it died and sits at my buddies place one hour away. So every time I get an idea I drive an hour to work on it and I have to haul all my tools over then back. It's getting old, I don't get much time to work on it and I waste 2 hours each time.
At first I saw it wasn't getting fuel and I put power to the pump and didn't hear anything so I hooked up a pump and complete tank from another truck I just parted that was running perfect, and also changed the fuel filter.
That didn't do anything, so I thought the ignition module since it controls the pump.
Changed it a couple of days ago, it did hint that it wanted to start, it was getting fuel but still no start, and finally not even a hint of starting, so I started looking around and found one spark plug wire touching the exhaust manifold and the boot was pretty nuch done and so was the wire.
The rotor and cap are new and the only part I haven't changed is the coil.
Could the plug wire have shorted and killed my new ignition module?
What else is there to check?
I can hear the pump coming on now and I see fuel in the throttle body.
The only thing I haven't confirmed yet is the spark and I can't do it alone, but I even tried starting fluid and nothing, like there is no spark?
I really need to get it running so I know it's a good engine to sell it but if I can't figure it out I will just yank it and put my diesel in there which is what I want to do anyways.
It would be nice if I can get it to run in the truck first though.
