Can't use just a spacer, you'll need an adapter. Assuming you use a stock GM "spread bore" intake, you need a spread bore carb to big block TBI adapter. Trans-dapt makes and sells them, just saw some on summitracing.com for just under $50.
No idea how this may affect things like throttle valve for transmissions or throttle cable.
