454 TBI's
b454rat
Binghamton NY
I got 2 454 throttle body's laying around that I'm not gonna use. 1 is incomplete, has injectors and pressure regulator. Adapter too.
Other one is complete, bolt on and go. Pulled it off a running truck. Unit is rebuilt, has a sticker on the main body. Got some of the wiring for IAC and TPS. Adapter as well.
I can get pics of yah need, shipping should be cheap and easy as they should fit in a flatrate box.
Looking for trades, nothing in particular. I need a Detroit for a 14ff, could throw some cash in too. If not make an offer....
The whole TB was rebuilt, if you look on the left side you can see a sticker, tried to get a good shot of it but didnt' come out.
I have a 87' 7747 ECM/harness, but it's for a 350. It will work, but will a 454 chip, and swap around the IAC and TPS wires, which should be on that TB. I also have a 91' 7060 ECM/harness for a 350/4l80, and a ECM for a 454/4l80 with a Jet chip in it. Again I think you would have to swap out the IAC and TPS wires.
