Has anyone used hydroboost with ram assist? Does it work well or would the older type brake booster set up be better?
The 454 vortec uses hydroboost for its brakes. I will be installing the 454 vortec in place of a 350 TBI which used a brake booster w/vacuum.
I have the hydroboost from the truck that the 454 vortec came from. Will this work with ram assist or should I look for ways to use the brake booster set up from the TBI?
I believe the only way to use the brake booster set up is to tap into the PCV line for vacuum. Not sure I want to do that so that's why I'm asking for options and opinions.
