Just picked up a 366td for my blazer, it came with 473328.....68-69...oval...OPEN...366T and I have 14092360...86-90...oval...OPEN...454 Truck, "peanut" round ports. As far as any #s have told me these are the same heads, I'm trying to find out which one has bigger valves if at all or if one has a smaller combustion chamber for compression or does the "peanut" heads simply flow better. I plan on gasket matching either set I use and the motor has an "rv" cam, what size exactly I don't know.. Any knowledge would be helpful.. thanks.
