465/205/44/14ff 4.10 Gears Warn Hubs Moded For 15in Wheels
gn4u2c
Pa 17329 zip
These are in great shape bolt in and go ! raised sreeing arm for 4-6 inch lift, warn lockouts, good brakes, everything is tight. drum/drum hub/hub nothing missing $400.00 for the set
sm465 works great $150.00
205 with 465 adaptor $150.00
I have everything you need still on the truck ! This is a complete truck at the moment will be parting as needed. If you need everything to switch to 4 speed I have it all - colum.
6' lift front springs , rear blocks, superlift shocks with red boots u bolts and all. this kit looks to be fairly new as the shocks do not have any scrapes or rust on them. u bolts are not rusted ither. $150.00 for it all
driveshafts for lb truck $25.00 rear, $50.00 for the front very tight.
Must pickup parts unless you arrange and pay for transport I will help load.
all parts from 1976 truck with low miles but rusted up as most are.
Glenville Pa 17329 zip. pm me me for details or a time to pick stuff up. I will need a few hours to remove the parts for you before you come.
u wouldnt happen to have the 15" 8 luggers would you? if so, let me know. i need some asap!
would u part out the front? im looking for 8 lug conversion. let me know.
I have several other 44's that are 8 lug yes I will part or you can stop up and pick up a hole working 8 lug front for $100.00
let me know 443-398-7326
jason
just off I-83 exit for middletown rd
