465/205 gaskets?
bigbadchev84
Hermiston, Oregon
does a figure 8 205/465 have gaskets that need to go between them and the adapter? I currently just have silicone and it is leaking, Not sure how well it was done, Napa did not have a listing for gaskets, everyone else just using silicone?
Yes they use gaskets. According to previous posts I read, they are required. Just can't recall if it's because the adapter bottoms out on the bearings before seating flush, or that the bearings don't need the preload.
mine came with the transmission whe it came rebuilt, i'd ask a transmission shop if you can't find anyplace else, miine still slightly leaks though, doh! but use rtv and let it try a little so it makes a gaskret better and doesn't just smear all over the place
Buy some gasket material and make your own.
Can you buy thick enough material? The gaskets used that I had are double the thickness (at least) of the gasket making sheets I've seen.
hey so does anyone know where i can order these online? i have the older 465/205 and its leaking everywhere seems like. im doing my hydro clutch soon and would like to redo all the gaskets whiles it out.
I ordered mine from this place.
http://www.natauto.com/catalog.htm
They don't have an on line catalog,but here are the part #'s
& what I paid about a year ago.
Complete SM465 gasket & seal kit .
P/N KTS-364 $14.25
Here's one for a NP 205 also.
P/N TCK-205G $19.50
Mines older, and price wasn't as good as the above post, but if you need someplace else, here you go:
http://coloradok5.com/forums/showthread.php?t=123543&highlight=gasket+set
Here's a picture of the kit contents:
But like I say in the post, the shipping was a killer. Packaged right that set could fit in a flat rate envelope I suspect....
