ok, for clarification, i'm referring to the gears in the following order:
the lowest gear = L
next up = 1
next = 2
next = 3.
ok, so when shifting from 1-2 and occasionally from 2-3 in a suburban i've been using for a few days now, the gears grind. if i push the shifter up toward 2 and leave it there for a second and then shift into the gear, it won't grind.
i don't have trouble getting into L, 1 or R, just the two i've mentioned.
This truck has a hydro clutch. syncros? thoughts?
the lowest gear = L
next up = 1
next = 2
next = 3.
