I'm planning for the next work after I finish my body work. My 1977 K5 has a 468Big Block that seems to run fine. Previous owner installed electric fuel pump. While I appreciate the New Green Deal approved Big Block I am eager to swap down to the 350 just because it will be a NEW crate motor that I get to install and maintain from new myself. Also want to go back to mechanical fuel pump (easier and cheaper to fix)
Axles are D60 and 14Bolt with 4.10 gears. 700R4 transmission and NP 205 Xfer case.
Would the 350 suffice to power this rig? 95% Daily Driver
