One of the things I had difficulty with regarding my engine rebuild was finding a list of parts that seemed to work together for my old 468 block. I made sure that me and The Machinist keep track of all parts added to this rebuild. The parts list with corresponding part numbers is included below. I also included before and after pictures. I do not have a picture of the engine with the valve covers on it yet but I will add that soon.
Also, could not have done this without alot of guidance and parts from Heath @folkenheath (Volcano manifolds)
468 - 496 BBC PARTS LIST
*Edelbrock Pro-Flo 4 Intake System 35830
*Volcano Manifolds - Volcano Intake Insert
*Brodix Aluminum Heads 2061000
Oval Port
*Stewart High Flow Water Pump 72231-BCP
*CompCams Roller Rocker Arms 1620-16
*Howards Cams and Hydraulic Roller Lifters Kit - CL122115-14 (Includes Cam 54939 and
Hydraulic Roller Lifters 91167)
*Callies - Compstar Forged H-Beam Connecting Rods CSB6385 ES3B9AH
*Edelbrock Distributor Ignition Control 3674
*LPC Timing Set LT98510T-9
*Durabond Cam Bearings CH-12
*Mahle/Clevite Bearings CB-743HN
*Mahle/Clevite Bearings MS-829H
*LPC Pushrods Exhaust LPR-8700-80-8
*LPC Pushrods Intake 3-7700-80-8
*Total Seal Piston Rings CR-9190-65
*Moroso BBC Oil Pan 20451
*Moroso Oil Pan Gasket 93153
*Moroso Windage Tray 23030
*Cloyes Timing Cover 2 Piece 9-231
*FelPro Timing Cover Gasket Set TCS-45060
*Chevy Performance Valve Covers HLY-241-281
*FelPro Valve Cover Gaskets 1635
*LPC Billet Timing Pointer LPC-TP4725-B
*Melling Expansion Plug Set MPE102-BR
*ATI Super Damper ATI917060
*ARP Harmonic Balancer Bolt 135-2501
*ARP Main Bearing Studs/Bolts 235-5701
*ARP Head Bolts 135-3601
*ARP SS Hex Oil Pan Bolts 435-1802
*Edelbrock Intake Gaskets 7203
*PermaTorque Head Gaskets 1071-053
*Melling Oil Pump M-77HV
*ARP Oil Pump Shaft 135-7901
*POR15 Engine Enamel - Chevy Orange #42268
Please don't ask me to total the cost... I'm afraid to know.
Hope to also get the VintageAir brackets and accessories on soon. The Stewart Water Pump is slightly interfering with the timing cover. I'll need to grind down part of the water pump legs for proper fit but that shouldn't be a big deal.
Oval Port
