Blazer79
My 454 finally died last weekend, spinning a bearing
Previous owner was a wrecker and was in service for who knows how many thousand miles. I bought it from him 10 years ago and did countless trips of 4x4, so I'd say it's fair to have a catastrophic failure now.
I've been researching, and have always liked the idea of having a 489 stroker. But now that I started shopping, stroker kits are so expensive.
Summit carries SCAT cast steel kit for $1,400. I also need a pair of headers, so if I go with the cheapest ceramic coated headers, it'd be about $300 more. So I'd be spending about $1,700.
On the other hand, I can buy a hypereutectic 454 kit from summit for $480, get a set of Doug's headers for $570 and a set of total seal rings that give you a little extra hp for about $200. Thats $1,250.
I already have a Comp cams 4x4 K-kit, and a set of 049 with enlarged valves which would go into either of my choices.
So I now come asking for your help and recommendations. Which option would be better? What would you guys do? Does a stroker kit really give you that neck-snapping power? Or is it just too expensive for what you get in return? Are total seal rings worth it too?
Any other ideas are welcome.
Previous owner was a wrecker and was in service for who knows how many thousand miles. I bought it from him 10 years ago and did countless trips of 4x4, so I'd say it's fair to have a catastrophic failure now.I've been researching, and have always liked the idea of having a 489 stroker. But now that I started shopping, stroker kits are so expensive.
Summit carries SCAT cast steel kit for $1,400. I also need a pair of headers, so if I go with the cheapest ceramic coated headers, it'd be about $300 more. So I'd be spending about $1,700.On the other hand, I can buy a hypereutectic 454 kit from summit for $480, get a set of Doug's headers for $570 and a set of total seal rings that give you a little extra hp for about $200. Thats $1,250.
