LongroofJosh
Registered Member
I'm mid stream in my build and thought it would be nice to give back to this forum by posting my project with pictures and how I did certain things so others can pull from the info on thier build, since thats what I did.
Body and frame is a 1989 suburban registered as a diesel.
Ive pulled the suspension, axles, motor, trans and transfercase to make room for 1-ton axles, 64 inch rear leafs, 56 inch front leafs, cummins 4bt motor, a518 trans with a 205 transfercase. My goal is a daily driver getting 26-30 mpg capable of completing trails such as the rubicon.
So far I have built the rear 3.73 14 bolt FF axle and added rear disc brakes. I installed 64 rear leafs off a 2004 duramax 2500 by using a ORD shackle flip and moving the stock front hangers forward.
Up front I installed my dana60 with 3.73 gears. But getting ready to pull it out again to install 56 inch rear springs up front. Hopefully this will be a good decision.
