4cyl 5 spd to v8 with same 5 spd
55Willy
3/4 ton status
Keizer, Or
in doing a 2.5 to a v8 swap while keeping the 5 speed. what clutch and flywheel do I need to use?
i would us one that is made for that tranny behind a larger engine, but i would not really truck a 4 banger tranny behind a v8
Should be a T5. I would guess that a T5 from behind a 4.3 (if that ever existed) would be the ticket. If you can't find that, 305 f-bodies came with a t5 that could work. Should all be hydro clutch setups too.
i sat the rig on fire so I'm parting it out and will be building soemthing else. thanks for the help though.
