4L60e Issue
jfkelley
Registered Member
Oklahoma City
1977 K10 4x4 , LM7/4L60e/ NP241c ..Received a call from my tuner..The transmission was acting really odd. It would go for a bit then go into neutral and not move forward or back. Topped fluid off before tuning. Not sure if we have a sensor miscommunication or what. Going to scan it today and see if I can come up with some idea…Anyone ever had this issue ..
My guess would to check fluid pressures to make sure pump is working since you have no forward or reverse movement.
This, I’m sure you check the fluid level warm? If the fluid shows good and it still won’t move the trans should function if it isn’t destroyed.
I sure hope it’s not the transmission..I drove the original donor truck before I pulled everything for my K10
