Before I pull this thing back out I wanted to see if you guys had any ideas on a problem we're having with a 4l60e in a 2002 GMC.
We pulled it out to replace the flywheel bolts, and while it was out we decided to put a transgo shift kit in it. I put the kit in, following the directions carefully. Everything was simple any pretty straight forward. Get the trans back in the truck and put fluid in it. After putting 4 quarts in it it read above full on the dipstick. The trans was drained, but the converter wasnt completely drained.
Truck will not go into gear. Gear selector illuminates, truck increases RPM, but no movement. I pulled the cooler line and fired it up. Nothing. Figured it might just be low, so I put a few more quarts in. Put it back in gear. Nothing. Let it run a little bit to see if fluid will circulate. Nothing. Pull the cooler lines again, nothing. Look under the truck while its running, it starts puking fluid out of the vent. Fluid on dipstick is high, like the dipstick tube is filling up. Trans pan is cool to the touch. Attempted to remove the drain bolt to see if we could drain some fluid but the drain bolt was seized. Any ideas?
Cliffs: Installed shift kit, trans wont run. Pump doesnt seem to be sending fluid to the cooler. Trans is puking fluid out of the breather when in gear. Dipstick is showing over full when the trans should have 10 quarts in it at the most.
