4L80 and doubler
clstolten
If the ecm needs to know when the transfer case is in low, and it has the transfer case ratio programmed into it, how are people dealing with the additional transfer case ratios involved with a doubler? Or, is it really not a big deal, and you program the ecm for the transfercase ratio you will use most often? Will the transmission shift funny when you use the additional transfer case ratios?
fast easy of it.
do a 2wd 4l80 with the 4wd tail shaft in it . then it never needs to know the final output. make sure its a true 2wd version tho. early 4wd got rear tone ring but sensor hole pluged off. later 4x4 got the tone ring left out so you cant just add the rear sensor to the hole. pull the plug and if you can see a tone ring in there then just add the sensor and run it as a 2wd .
and if you havent seen my build up of it read up here for the basics . http://coloradok5.com/forums/showthread.php?t=253000
Hmmmm. I have wondered why gm didnt do it that way, but figured there must be a reason. Maybe the reason is as simple as the signal is also used for the speedometer. But, if that was true they could have installed the sensor like you say, and then just calculate mph with the same switch, and known transfercase ratio. Probably easier for them to just add the multiplier for low and keep the sensor at the output on the 4wd units rather than changing the program to work the other way.
Do you know if the shift points are at all based on mph?
I will have to look at the transmission I have to see if the tone ring is installed. I am guessing not, since it is an 04. I am also guessing all of the guts have to come out in order to install the ring. Thanks for your input.
fast easy of it.
So I have a 4x4 4L80e, and want to run a doubler as well. Is this NOT the good tranny to use???!!! What do I have to do to convert it? I still need to go through your thread too, but just saw this and was like WTF! My tranny is no good! I hope I'm wrong. It cost me $675 for the damn thing.
Now theres some stuff in this thread i dont agree with, not saying im right, just probably confused.
The TBI trucks used a VSS in the tail shaft of the case, right? So, even in 4 low, it still only reads output speeds. So how does the TCM know its in 4 low? That VSS sensor? The 4wd light? The Switch inside the case?
If thats true, then the doubler case would need to be a 1991 205 out of a one ton. That would have the VSS in it, and would also need to have whatever switch it is that tells the TCM its in four low.
As for the 2wd transmission, I know it doesnt matter, but your speedo would be WAY off in four low.
There is a switch in the transfer case to tell the tcm it is in low. The tcm also knows the transfer case ratio. The 91 205 had a switch on one of the shift rails.
I think installing the ring/sensor at the 2wd location would work fine, but my concern is that the tcm may use mph as a factor to determine shift points. Also if your trans doesnt already have the ring installed, you will have to take all the guts out of the trans to install one.
I'm not sure how smart the pcm actually is and how that varies through the years. I imagine newer computers are smarter than old ones but I don't know for sure if they really know that 2:1 or 4:1 are not 2.7:1. It's very possible we're overthinking this.
What we know works is running the trans with the output drum speed sensor and never telling it when we go to low gear. This is the system we use in our "Cousin Willard" crewcab with a compushift controller and it works fine. We do tend to shift it manually more than others might when we're offroad and the controller does have a full manual mode that we use sometimes.
I do have a couple customers (that finished and drove the projects and got back to us with some results) that have run the computer totally off a tone sensor in the back of the 205 and report no problems with the trans controller freaking out over the low ratios not matching up.
Our safe answer has been to run the speed sensor on the back of the trans and just never tell it that the t-case is in low gear. On a 4L60 you have to use an adapter with a speed sensor port or add a speed sensor port in the back of the trans to do this. Or use a manual controller.
Stephen,
Thanks for the reply. I have done a bit of internet research on this over the past couple of days. Here is what I found out. Remember this is internet knowledge. If I am wrong about something I hope somebody will correct me. I did not look into the old TBI computer logic, so this info may not apply to those vehicles. I do want to correct myself about something I posted earlier. I believe the switch on the shift rail of the 91 NP205 case is only used for a light in the dash and not used for a signal to the TBI computer. I have seen the switch on much older 205's. Also this may not apply to aftermarket trans controllers. My K5 has a 2004 8.1 with a 4l85 trans.
For the newer LS stuff with a 4l60/4l65/4l80/4l85 transmission, there is a speed sensor on the trans post torque converter and at the trans output for 2wd or at the t-case output for 4wd. The sensor at the 2wd output or the 4wd t-case output is only used to verify the trans internal clutches are not slipping and for the speedometer. The signal is compared to the post tc signal and the trans knows what gear it is in. Transmission shift points are based on throttle position, engine rpm, and mph. When the transfer case is put into low gear, a switch lets the computer know it is in low. The transfer case ratio is programmed into the computer, and it can continue to monitor internal clutch slippage and provide a correct mph signal to the speedometer. What it also does is use a low range shift table. Shift points have been programmed to work properly with the lower transfer case gear.
On these computers/transmissions, if you add additional transfer case ratios you must use a speed sensor at the tailshaft of the transmission. If you use a speed sensor at the transfer case output, you will not be able to program the computer for the additional ratios and the computer will go into limp mode because the input shaft rpm vs the output shaft rpm will not be correct to the computer. As far as I can tell, you can only program for one transfer case low gear, and not 3. Maybe if you are a computer geek, you could figure out how to add additional shift tables selected via switches on transfer case levers. If you can do this, let me know.
If you use the speed sensor at the tailshaft of the transmission, and you do not ever tell the transmission that the transfer case is in low gear it will work, but may not work to your liking. The reason I say not to your liking is because it will use the same shift table that was used for high gear in the transfer case. In low gear, the mph signal will be incorrect for obvious reasons. Remember, the transmission shift points are based on throttle position, engine rpm and mph. In order to upshift, the computer must see a pre-determined engine rpm and a pre-determined mph. Those values will change with different throttle positions. So, the way I see it, the mph requirement for an upshift will be met sooner than expected, but it will shift when the engine rpm reaches the preset number. My guess is that gm programs the trans to shift at higher rpm in low gear depending on the throttle position. If I were to use a speed sensor in the tailshaft of the trans, I would let the computer know I was in 2:1 (original doubler) or 2.7:1/2:1 (magnum) by tripping a switch on the transfer case shift linkage. The actual ratio programmed in to the computer would be 1:1 for this. This would allow for the use of the secondary shift table. Then for the 4:1 (original doubler) or 5.3:1 (magnum), I would shift the trans manually. The way I see it this gear would only be used for real technical obstacles, so manual shifting would be preferred anyways???
Here is my dilemma: my 4l85 does not appear to have the speed sensor ring installed. Somebody tell me I am wrong. I took this pic today of the sensor hole after I removed the plastic plug:
Not exactly sure how I would install a sensor ring, but I am pretty sure I don't have the correct tools to remove the guts of the trans myself. Does anybody know how many labor hours would be charged by a shop to do the work, and how much the sensor ring costs? At this point I am seriously considering the Lomax instead of a doubler. I am looking for opinions from people who actually wheel their truck to tell my why I shouldn't go with the Lomax. I live in Colorado, so I will be wheeling lots of rocks. My truck will be full bodied and I don't want to rip it to shreds, so I wont be doing any trails that would do that. I have 5.13 gears in the axles, and 39.5 swampers that measure out to about 38.5". Stephen, I remember you guys were Lomax distributors. Do you know anything about the limited December production run they are doing on this case and gears? Do I need to order this month in order to get one? Do you know if the case and gears are made in the USA? I already have a NP205 tailhousing with sensor, so this swap would be easy. The 3:1 of the Lomax could be programmed into the trans computer, and it is very close to the 2.7 that the computer is now programmed for. Low gear shift table should be very close to ideal.
I appreciate any info. Thanks guys.
I don't know for sure if this would work but the knowledge for it to work or not is out there. In the diesel world you can use EFI live to make what they call the DSP5 switch. It's five switchable programs that can be done on the fly.
Why not try to get a DSP5 set up with a Valet mode, normal driving, off road high range, off-road low range and off road double low. Each of those is technically a different program in the switch (I think) so you can have three different offroad gear ratios programmed into the computer.
Someone knowledgeable about EFI Live could fill in the blanks on this and let you know if they can control the trans that much.
I wonder if the computer really is smart enough to know that the 2:1 low gear is different from a 2.72 low gear? I know all the tools are there and your generation computer should be able to do it but does it really?
I did come up with a decent way to fool the computer with a doubler. If you install 2 speed sensors on the tailhousing to read in 2 different zones on the tone ring you can remove 1/2 the teeth on the tone wheel to cut the number of pulses down. Not sure if this would be useful or not but it's a way to fool the system. I know this could be done electronically too by filtering the signal and dropping every other pulse but either way is a little cumbersome.
Your trans doesn't appear to have the tone ring on the output drum and it's a total teardown to change that drum. It's been a while since I looked in there so maybe someone else can verify this but that's what I see.
Your idea for running one "correct" ratio and manually shifting the lower ratio may be the most workable if the trans doesn't actually disable itself in some way. I wish we had a factory ECM system in the stable here since it's hard to compare the compushift system to what you have. Maybe someone that has access to the factory computer can change the gear ratio in a stock truck to 2:1 and see if it freaks out with the 2.72 ratio?
The dsp5 thing seems like a good idea. I talked to an engine buddy today that knows a guy working through some problems with this and may have some more info tomorrow afternoon. I like the idea of a multi position switch on the gas motor since it has so much awesome on the diesels and maybe this is the way to make it "necessary".
I'll take another look but I thought the switch on the Tcase was just to turn on the 4x4 indicator light and was not wired to the ECM.
Sounds interesting. I may try and contact EFI Live to see what they say about using the DSP5 in this application.
Good thinking on removing half the teeth on half the tone wheel, but I think that is the opposite of what is needed. Just thinking out loud, but in 2:1, if you have one revolution of the trans tailshaft you get 1/2 revolution of the t-case output. The computer is easily programmed to accept this 2:1. Now, if you put the tcase in 4:1. One revolution of the trans tailshaft will produce 1/4 revolution at the tcase output. You would have to double the pulses at the sensor to fool the computer and make it see the expected 1/2 revolution. The only way this would work would be if you could program the computer on how many pulses equal one revolution, and then you could run the modified half of the ring in 1:1 and 2:1, then switch to the un-modified half of the ring in 4:1 in order to fool the computer.
Who would I talk to on the dsp5 thing. I have LQ9 4L80E to doubler. I have green 16 pinned out on ground switch for 2.7 gear but in low low it drives through the brakes, so I never use it.
Honestly I would have to say try talking with someone in the United States about EFI live, maybe their website has some contact info? I think they're an Australian company is the reason I say in the US.
I don't know enough about any of this to be more than dangerous honestly.
hmm, interesting thread, not trying to hijack.. i'm swapping in a 2wd 4L80E into my suburban using a divorced np205. i'm using the engine/trans along with the OEM harnesses/ECM. should i expect any problems? not sure how much time i'll spend in 4-LOW or if 2:1 is low enough to mess with it.
hijack off
There are a couple of options for dealing with the 4l60/80/85 speed sensor problem:
Run the speed sensor in the transfer case and see what happens, may have to modify the software in the PCM to eliminate transmission slippage codes. (I can do that)
Or, (what I did with my 4l80) use a tone ring from a 241 and machine the I.D. to fit the input of the first transfer case and drill and tap the transfer case adapter to accept a speed sensor. I don't know what your adapter looks like so this may not be an option.
hijack off
With a 2wd 4l80 you can use the stock output speed sensor that is already in the trans, the PCM won't know it's in low range. Your stock speedo will simply run off the 205 so you can still run your mechanical speedo which isn't really an option if you move the VSS to the transfer case.
