broncoman6524
0411 PCM
Custom harness
LQ9
"96" 4L80E
FTI 3K lockup converter.
Tuner setup converter to lock at 45mph, it won't lockup on it's own. However if he commands it to (using HP tuners) it will lockup.
I've verified my TCC relay is wired properly. Purple 33 has keyed 12V, once brake is applied the power goes away.
Fluid level is correct.
Trans is a junkyard pullout, they told me it worked properly. I'm inclined to believe them, as it shifts phenomenally and doesn't slip.
Where should I start? I presume this is either a tune issue, or an internal trans sensor issue.
Custom harness
LQ9
"96" 4L80E
