4l80e/203/205
1967k10
Nebraska looking for D60's
I'm trying to find some info for a guy who has this idea in mind. A 4L80E/32spline 203/32spline 205.
I'm not familiar with the 4L80E/205 adapter but I'd assume you would need that and redrill the face on the 203 but not sure :confused:
Any thoughts on how?
You can use an NP241 adapter and slightly modify a couple of holes....
This is a previous mock-up I did with a 454BBC/4L80E/NP241 Adapter/203/Doubler/NP205.
Pretty simple and using the 241 adapter is a lot cheaper and simpler than sourcing some obscure 205 "1 year only"-type adapter.
:usaflag:
BTW -> I still have that modified NP241 adapter sitting in my garage if you want to make life easy for yourself. Send me a PM or whatever. :deal:
could you also use a th400/203 adapter and add a spacer or something? i think the output shaft on the 4L80E is longer than the th400, but im not positive
