4l80e 205 203
jimmypop
So-Cal
I have a 80e and np205. I want to do a doubler setup, which np203 should i use? Year, th400/th350,1ton any stout models or does it not matter.:confused:
Thanks
Victor.......
best way is the 32 spline 203 range box, you dont need the adaptor. then use a newer round bolt pattern adaptor from like a 241 tcase or such. redrill the 203 face and tap the holes. then do the dubbler.
this is the most comon way i have read every one doing.
