4l80e/205 shifter & brace rod
I am thinking the shifter and rod will be different since the 4l80e will be longer than the other trannys. Truck currently has a 400/205, guess I will just have to try and make them work.
just a little bending to tweek the shifter. then cut and weld in a section to the brace rod.
what you want is a 1 year only thing from 91. sorry.
