4L80E/241 Combo
pomai
Oahu, Hawaii
I need help!
the 241 wont mate up with the 4L80E trans, there is approxemently a 1/2" gap. I removed the adapter and slid the transfer case on to see what is the cause.
I hope that the pictures will explain better then I can, my problem.
wrong output? input? adapter? What's Wrong?
Thankk You,
Ed
I have a 2001 4L80E/NP263 here. The adapter is 2.48 thick. The tail shaft splines 2.78(?)
That's all I can tell you, trans is obviously torn down right now.
IIRC the shaft stick out should be 2 & 7/8”. ORD covers most of this on their tech page.
You have a full spline 2wd shaft cut down . Thats the problem .
Look at yours and the pic posted by 6872xtc of a TRUE 4x4 shaft .
You have 2 simple options . Clocking ring as a spacer . Or cut the 241 input gear nose off a tiny bit .
I had to cut down my 203 input for this EXACT problem . Its all in my 203/205 doubler thread in the advanced section here .
https://ck5.com/forums/threads/4l80...icked-its-all-done.253000/page-2#post-2553457
here is the specific thread and pics .
correct / true 4wd shaft
16128999498344538067424087852504-jpg.368117
your 2wd shaft with NUB RING
p1040822-jpg.368120
full length spline 2wd shaft un cut . notice the NUB RING
4l80-e-to-203-range-box-jpg.82878
Thank you everyone for your help.
Sending the Trans & transfercase back to make it correct, All the way from Hawaii.
Thanks again,
Ed
problem should be just the trans shaft .
and at this point just use a clocking ring as a spacer and be done with it .
but up to you and good luck on the project . glad we could help .
and how did it get the 2wd shaft in it when built for 4x4 ? if we can ask . and who built it ?
Are there different length 32 spline input shafts for the 241C transfercase?
I seen 2 different size bearings for it but have not seen different lengths?
Thank you,
Ed
There are not different length 32 spline inputs as far as I know.
Maybe trim a little off of the input on the t-case and output of the trans? Looks like you'd still have plenty of spline engagement.
i have been beating my 203/205 doubler with the cut down 203 input from the doubler thread i linked here now for 2 years . even had the unit out for other problem and no signs or wear or cracking .
since your way out there i would do the clock ring and if any extra needed trim a tiny bit off the input gear .
unless your builder screwed up and is admitting this and covering the shipping both ways and you can live with the down time then you have a few solid options in this thread .
