4L80E AWD to 4WD question...
shiner2001
Registered Member
Texas
It's been months since I've been on here and about that long since I've worked on this project, so please forgive me for my ignorance. Vehicle in question is a 90 V2500 4wd.
The background is that I have an 04 6.0L from a GMC 2500 HD 4WD. I want to get the same year 4L80E to mate with it. I found one from an 04 Denali that's listed as an AWD. I don't know what the transfer case situation in on an AWD Denali, but I am using the stock 241C transfer case from my Suburban...will that bolt to this tranny? I know the differences in the tailshafts of the 2wd and 4wd trannies, but the AWD is new to me.
I'm 98% sure that Denali has a 4l60. That's about as much help as I can be.
Crap, I think you're right. Or at least it's a 4L65E, but not a 4L80E nonetheless. I was under the impression that if something had the 6.0, it had the 4L80E. Looks like I was wrong! I probably just need to stick to the plan of finding a K2500 HD for a donor.
Almost any 91 and up 1 ton and 95 and up 3/4 should have 4l80's in them. I just bought a 95 3/4 ton burb. 9.25 ifs. 14bsf. Hydro boost, and a 4l80e in it. Shouldn't be to hard to find one although I believe behind an LS you will need a spacer for the older 4l80s.
